3D Printing saved Italian hospital when supply chain issues threaten patients
Brescia’s hospital had 250 COVID-19 patients, many of which needed to use respirators. Unfortunately, these respirators need their valves replaced every 8 hours, which quickly say the hospital run through its stock of valves, and their suppliers were unable to supply the hospital with new valves fast enough.
Lives were at risk, but thanks to 3D printing, the situation was eventually resolved. An Italian journalist, Nunzia Vallini, put Brescia’s hospital in touch with Cristian Francassi, the CEO of Isinnova, who, with the assistance of mechanical engineer Alessandro Romaioli, was able to design a manufacture a 3D printed prototype valve within three hours of seeing an original ventilator valve.
After receiving a prototype, the Brescia hospital quickly tested their 3D Printed replacement valve on a patient, confirming that that new valve functioned correctly. After that, Francassi returned to his office to start producing more replacement valves. The image below compares a standard respirator valve (left), with a 3D printed replacement valve (right).
(Image from 3D Printing Media)
Later, Francassi and Romaioli contacted another local 3D printing company, Lonati SpA, so that they could assist in producing replacement valves. Isinnova has six 3D printers in operation, and every valve takes around an hour to produce. Isinnova’s valves were printed using a filament extrusion system, a method that’s popular for hobbyist 3D printers.
Lonati used a different method to produce its replacement valves, using a polymer laser powder bed fusion process to complete its work. This a wholly different 3D printing process, but it was able to assist in creating replacement valves in larger volumes. Below is an image of Lonati SpA’s valves.
At this time, Isinnova has no plans to release the STL files for its 3D printable respirator valves publically. Both Isinnova and Lonati SpA are creating these respirator valves for free, and each valve is said to cost €1 to produce.
You can join the discussion on 3D printing saving lives at Italian hospitals on the OC3D Forums.
