Anidees AI5S Case Review
Owing to it’s small size, when we first clapped eyes on the box containing the AI5S from Anidees we were convinced the case inside could only be an M_ATX case at best. Picking the box up did little to reassure us that we dealing with a decent product, so light was it that we felt it ought to be tied down if the wind picked up. We further figured that as it was so light, it could hardly have a decent spec and was most liekly one of those bottom of the range cut price jobs we occasionally see. We were though, very wrong on both accounts, as you’ll shortly find out.
Technical Specification
| Colour | Black |
| Materials | Steel and Plastic |
| Dimensions | 430x220x470mm (HxWxD) |
| Weight | 5.96kg |
| Motherboard | ATX, M-ATX |
| 3.5″ | 5 |
| 2.5″ | 9 (3 shared with 3.5″) |
| Front I/O | 2xUSB3.0, 2xUSB2.0, Fan Controller, 2xAudio |
| Expansion Slots | 8 |
| Air Cooling |
Front: Up to 3x120mm/2x14mm (2x120mm included) Roof: Up to 2x120mm/140mm Rear: 1x120mm/140mm (1x120mm included) |
| Water Cooling |
Front: 240/280mm rad Roof: 240/280mm rad Rear: 120/140mm rad |
| Max PSU length | 220mm, (350mm with HDD cage removed |
| Max GPU Length | 340mm |
| Max CPU Cooler Height | 175mm |
