Cooler Master Eisberg 240L Prestige Review
We reviewed the smaller single radiator version, the 120L prestige back in June 2013 and it’s fair to say we weren’t overly impressed with it. With all thoughts of it out of our mind we approach the larger version, the 240L Prestige with unsullied thoughts and a spring in our step. As you might have guessed this is a double width version of the 120L, coming as it does with 2x120mm 1600rpm fans. Double the surface area should make for improved performance and of course the Eisberg range offer what conventional AIOs do not. Although at point of delivery the 240L is essentially and AIO it can be taken apart, added to and expanded. This flexibility though comes at a price. At £131 It’s a lot more expensive than traditional AIOs. To see what we’re getting for our money let’s take a look at the technical Specification.
Technical Specification
Intel Compatibility |
Socket 2011 |
AMD Compatibility |
Socket FM2 |
CPU Waterblock |
Copper Micro Channel CPU Waterblock |
Radiator |
2 x 120mm |
Radiator Dimensions |
280 x 124 x 30mm (without fan) |
Fan |
2 x 1600 rpm Coolermaster Fans |
Fan Connection |
3 Pin |
Fan Airflow |
60.2 CFM |
Fan Noise |
20.5 dBA |
Special Features |
All In One CPU Cooler |
Package Contents |
1 x Coolermaster Eisberg |
- Features
- German designed pump provides stable and strong water pressure
- JetStream Technology – provides turbo injection of water inside the waterblock
- Improved cold plate design:
- Easy installation with Eisberg mounting kit
- Large Micro Channel contact area
- – 100% copper
- – Fine cut Jet Plate
- – Integrated pump and waterblock
