CoolerMaster MasterAccessory LED Partition Plate Review
Packaging
Deep breath now, as for the one and only time in this review we’re going to call this item by it’s full name Ladies and Gentlemen, we give you the….. CoolerMaster MasterAccessory LED Partition Plate-Single Colour….Aaaaaad relax. We’ve actually got all three colours here to look at, with each of them coming extremely well packed in a flattish card box.
As you’d expect, the rear of the box gives details and key features of the product within.
Once opened we can see that the panel is embedded in a cut out of dense foam packaging. There’s actually another foam panel which goes over the top of this, but we’ve removed it so you can get a better view.
The instructions are clear and simple and come in the usual CoolerMaster long banner format. Not the easiest to use, but you can’t get mixed up with where you are in the process.
