CoolerMaster HAF 932 Full Tower
Packaging
The HAF comes packaged in pretty much what you expect to see, a sizable thick walled cardboard box. The front design shows off the case in all its glory, while the back gives a short blurb on the features along with a few shots of said features in action. At the side is a full specification list and yet another graphic of the case – but this time with the case powered off.
Pulling the case out the box we see it is protected with a large plastic bag and two moulded polystyrene spacers. Once again nothing out of the ordinary here, this method of shipping cases has been tried and tested to death and is quite acceptable.
The accessories come in a small cardboard box that was loose inside the case when I received it. A little concerning but the contents aren’t the harshest of things you could hit a steel plate with. The case comes with a small package consisting of the following:
Cooler Master need to be commended here for including some wheels in the package. As you will see later this was a very wise move on their part due to some of the features of the case. An extension cable for the 8 Pin power connector was a nice addition too, as many people will know the frustration of having to wait a few days for a new system simply because a wire was 2″ too short. The schematic of the motherboard tray was a little curious. What it laid out seemed a little like common sense to me but could be helpful to those not used to cable management.
Next up we take a look at the externals of the case…
