CoolerMaster Hyper 212X Review
Packaging and Contents
The Hyper 212X comes in a classic CoolerMaster style box, the exterior of which shows images of the cooler inside as well as giving details and technical data.
CoolerMaster Hyper 212X Review     CoolerMaster Hyper 212X Review
The Cooler itself is protected by a simple plastic moulding, which should do the job but isn’t nearly as environmentally friendly as the cardboard systems we’ve seen used.  Inside the box you’ll also find a smart little carton containing accessories and mounting hardware.
Now lets remember this is a £30 cooler.  So what do we get?  Well quite a lot actually.  Not only is there’s a universal mounting bracket and back-plate, but you also get a set of additional plastic fan mount clips, which are so much nicer than the cheap metal spring clips you’d usually get in a cooler at this price pint.  you also get a moulded plastic tray which contains all the bolts and screws you’re going to need.
Let’s take another look at that mounting hardware shall we.  Isn’t it nicely laid out.  And don’t go thinking this is one of those finger ripping vac pac things, it isn’t, it opens up easily and can be clipped closed when finished with to keep all the other hardware safe and organised.  In all the coolers we’ve tested we’ve never seen this before, not even with Noctua, and it’s fair to say we’re well impressed.
