CoolIT Freezone Elite CPU Cooler
The cooling systems employed by enthusiasts today are constantly increasing in complexity and expense, in a bid to increase efficiency, reduce noise and provide a means for increased overclocks. Todays review item is a product which, through use of a lesser known cooling solution, aims to hit these goals on the head and provide users with the best performance available without the need to insulate and risk hardware failure. Design: Monolithic copper, multi-cell
Dimensions: 43 x 42 x 16.5 mm
Weight: 175g
Design: Dual dissipation plate, anodized alloy
Dimensions: 121 x 92 x 65 mm
Weight: 800g
TECs (6)
Power usage: Max total 72 Watts
Design: Six solid-state heat pump wafers
Dimensions: 40 x 40 x 3.5 mm (each)
Weight: 20g (each)
Chiller FHE’s (2)
Design: Dual anodized alloy distribution, multi-channel
Dimensions: 121 x 41 x 12 mm (each)
Weight: 80g (each)
Fan
Power usage: Max 8 Watts
Airflow: 120 CFM
Noise: Max 40 dBA
Bearing Type: Dual ball
Life Cycle: 50,000 hrs
Dimensions: 120 x 120 x 38mm
Features: 3rd Wire Tachometer
Pump
Power usage: 8W +/- 0.5W
Design: 12VDC coreless outrunner pump with integrated expansion vessel
Noise: Dimensions: 50 x 50 x 75 mm
Flow: 3.5 L/minWeight: 205g
Options
Single/Dual CPU Cooling Solution
Dual GPU Cooling Solution
