Corsair Carbide Spec 04 Review
It’s been while since we’ve reviewed a budget case, so with this in mind we thought we’d take a look at the brand new Spec 04 from Corsair. At under £50 it’s certainly inexpensive. However, it’ll still need to cut the mustard if we’re to rate it, and especially if we’re to award it our coveted “Value” award. First impressions are that it’s a very light case,with a quick glance at the specs telling us it tips the scales at just 4.2kg. Let’s hope that Corsair haven’t cut back too much and made a case with the structural integrity of a crisp packet. For more detail let’s have a look at that all important Technical Specification
| Dimensions | 492x201x433mm LxWxH) |
| Material | Steel, Acrylic |
| Weight | 4.2kg |
| Motherboard | ATX, M-ATX, M-ITX |
| Front I/O | Power/Reset, 1xUSB2.0, 1xUSB3.0, Audio |
| Expansion Slots | 7 |
| 3.5″ | 3 |
| 2.5″ | 2 |
| Air Cooling |
Front: 2×120/140mm (1×120 included) Roof: 2x120mm Rear: 1x120mm |
| Water Cooling |
Front: 1×120/140mm Roof: None Rear: 1x120mm |
| Max CPU Cooler Height | 150mm |
| Max GPU Length | 370mm |
| Max PSU Length | 225mm |
