Corsair iCUE LINK TITAN II 360 RX LCD Review
A strong performer, an excellent screen, but a few caveats
This review has been strange, mostly because Corsair has done something different. That’s not a bad thing, and honestly, it’s good to have a product that changes the way we test things.
If you are building an AMD Ryzen-based PC, this is a strong cooler offering from Corsair. For users of Intel-based systems, things get complicated. If you want a Corsair cooler with a large screen, this is it, though it is worth noting that other Corsair units can be upgraded with this screen, as it is available as a cooler upgrade option for TITAN and TITAN II series coolers.
Corsair’s screen control software is solid. That’s to be expected for the company behind Elgato and the Corsair Xeneon Edge. These aspects of the Corsair iCUE LINK TITAN II 360 RX LCD are strengths, as is the overall appeal of Corsair iCUE. Easy cable management and good software control. What’s not to like?
An AMD-Optimised Design
The Corsair iCUE LINK TITAN II 360 RX LCD is an AMD-optimised CPU cooler. Corsair’s advertising makes this clear. Another way to put it is that this cooler isn’t optimal for Intel CPUs. On our Intel LGA1700-based cooling test system, this cooler isn’t ideal. Its performance isn’t the worst we have seen with an all-in-one liquid cooler, but it’s far from the best when using an Intel setup.
On our Ryzen 7 9800X3D setup, the new TITAN II delivers notably lower CPU temperatures at lower fan RPMs than the original TITAN. That means users can achieve solid CPU thermals with lower system noise. That’s a huge benefit. We also believe these benefits would grow even more with hotter dual-CCD AMD Ryzen CPUs. Sadly, we couldn’t test this as part of this review. That said, this AMD-optimised design is undoubtedly optimised for AMD dual-CCD CPUs (like the Ryzen 9 9950X3D).
What should Intel users buy?
So, what about Intel CPU users? What is the best Corsair iCUE CPU cooler for them? Honestly, if you want the iCUE LINK TITAN II RX LCD, I recommend getting the original TITAN (while it is still available) and buying Corsair’s iCUE LINK 5-inch LCD separately. Based on our testing, the original TITAN performs better than the TITAN II on our Intel-based test system. For AMD Ryzen users, the TITAN II is a better product.
It’s a little complicated, but it’s a good cooler
On its website, Corsair is upfront that its TITAN II CPU coolers are optimised for AMD CPUs. Yes, this cooler also ships with Intel mounts, but it’s the AMD mounts that come pre-installed. This cooler is made for AMD Ryzen CPUs, and it shows. That said, the 8-core Ryzen 7 9800X3D CPU we tested wasn’t hot enough to really challenge this CPU cooler.
This CPU cooler isn’t for everyone; it’s for AMD Ryzen users. Corsair sees how AMD is dominating the DIY PC market and gaming markets with its X3D CPUs. With this in mind, it is easy to see why Corsair has optimised its newest cooler for AMD CPUs. That’s how much the market has shifted over the past decade. Sadly, that means this isn’t the best CPU cooler for Intel users. That said, the original TITAN is still available, so Intel users can still buy that.
As for the TITAN II RX LCD’s screen, it is large and beautiful. Corsair’s LCD control software is top-notch, so there is very little to complain about there. You’d be surprised how many LCD-clad CPU coolers and cases do not get the software right. Software matters, and Corsair’s software is good, arguably industry-leading.
The Corsair TITAN II RX LCD is a great product, so long as you’re using an AMD Ryzen CPU. If not, then this CPU cooler is harder to recommend. That said, Corsair advertises this as AMD-optimised, so should you expect anything different?
Join the discussion on our Corsair iCUE LINK TITAN II RX LCD review on the OC3D Forums.
