Corsair iCUE LINK TITAN II 360 RX LCD Review
Meet the Corsair iCUE LINK TITAN II 360 RX LCD
Corsair has taken its all-in-one CPU liquid coolers to the next level with its TITAN II 360 LCD
Corsair started a new era of PC liquid cooling with its original iCUE Link TITAN all-in-one liquid coolers. The company moved on from Asetek pumps to its own FlowDrive designs, and the result was strong liquid-cooling performance. Today, we are looking at this cooler’s successor: the TITAN II, specifically the iCUE Link TITAN II 360 LCD.
Honestly, I was more than a little excited to hear this cooler existed. Yes, I’m a bit of an engineering nerd, so I was excited to see how Corsair’s new FlowDrive 2 pump performed. Corsair promised up to 30% greater flow than the original FlowDrive and increased durability. It also promised lower noise levels. These are nice upgrades, especially when combined with the TITAN II’s other changes.
Unified Fan Frame
Another upgrade is its unified fan design. Instead of using three separate 120mm fans, Corsair is shipping a single-frame 360mm fan unit. This means that all three fans can be controlled and powered using a single cable. Specifically, a single iCUE Link cable. Very nice! The single-frame nature of this fan makes it easy to install or uninstall, as you only need to screw/unscrew four screws instead of twelve.
Screen or no screen, your choice
Corsair’s iCUE Link TITAN II is available with and without its LCD screen. This cooler is modular, so users can choose if they want an LCD, don’t want it, or upgrade their non-LCD model with an LCD later.
Note that this CPU cooler is also compatible with Corsair’s other “CapSwap” AIO top modules.
iCUE LINK
As this cooler’s name suggests, the iCUE LINK TITAN II 360 RX LCD is part of Corsair’s iCUE LINK ecosystem. That means this cooler’s fans can be daisy-chained with other compatible fans and can easily be controlled using Corsair Link.
Like other new Corsair CPU coolers, the iCUE LINK TITAN II 360 RX LCD comes with pre-applied XTM70 thermal paste. This ensures strong cooling performance and a good thermal paste application with minimal effort.
HUGE LCD screen
This liquid cooler ships with Corsair’s iCUE LINK 5-inch LCD screen module. The screen is 5 inches, supports a 720×1280 resolution, and uses a DisplayPort input. This screen ships with the TITAN II RX LCD, but is available standalone as an upgrade option for compatible liquid cooling solutions. This screen operates at 60Hz, supports 24-bit colour depth, and can be controlled using Corsair’s iCUE LINK software.
Note that this screen can showcase system information, CPU temperatures, animated GIFs, iCUE Widgets, and more. The screen uses DisplayPort, so be prepared to route that cable and to connect it to your motherboard or GPU.
Corsair includes a PCIe bracket that allows users to easily route this cable out the back of their PCs. While this is a solid option, braver users may want to discreetly drill a hole inside their PC to route cables more “hidden” way behind their motherboard trays.
Pricing
Corsair’s iCUE LINK TITAN II RX LCD CPU cooler is available in the UK for £199.99, which is rather affordable for a CPU cooler with an LCD screen of this size. The CPU cooler is available in black and white, and a more affordable version of the TITAN II is available, which lacks this model’s large LCD screen.
The 5-inch LCD for the TITAN II RX LCD is available as a standalone product, and it supports Corsair TITAN and TITAN II CPU coolers.
OC3D CPU Cooler Test Rig Specifications
Recently, we built a new PC to test CPU coolers. This new PC has a newer, hotter-running CPU, a more power-hungry graphics card, and a cooling layout common in today’s gaming PCs. Simply put, we have moved to more modern hardware so that we can better test modern CPU cooling solutions.
Note that we add an extra top-mounted 120mm fan at the top/rear of the case when testing air-based CPU coolers.
CPU: Intel i5-14600K @1.27V (Fixed)
Motherboard: ASUS ROG Strix Z790-E Gaming WIFI
Case: Custom Lian Li O11 EVO XL
Memory: G.Skill Trident Z5 Neo DDR5-6000 32GB (2x16GB)
GPU: Sapphire RX 7900 GRE Nitro+
PSU: be quiet Dark Power 1,000W
Fans: 4x be quiet Silent Wings 4 fans
Note that for this review, we will also test this CPU cooler using an AMD-based test rig. This is due to the AMD-optimised nature of this CPU cooler.
