Corsair iCUE LINK TITAN II 360 RX LCD Review
Thermal Testing – (Intel) Gaming
OC3D CPU Cooler Gaming Test
With this new CPU testing rig, we wanted to experiment with analysing the “gaming” performance of CPU coolers. After all, all-core stress tests are not a common workload for most PC users. Games do not usually put huge levels of stress on all cores of your processor, especially if your CPU has a high core count. We also wanted to see if your choice of CPU cooler impacts GPU thermals under a GPU-focused stress test. After all, your CPU cooler can have a huge impact on the overall airflow pattern of your PC.
This testing procedure uncovered something. What we found was that AIO CPU liquid cooling solutions gave us lower GPU thermals. This makes sense, as these solutions pump hot air directly out of our test system and act as an exhaust. That said, the impact on GPU thermals was minimal. We only saw drops of 2-3 degrees during this test. Given this lack of difference, we will now focus exclusively on CPU thermals with this test.
For our CPU game test, we used Final Fantasy XIV Endwalker’s benchmarking tool for our gaming test. This test can run for a long time and moves between CPU and GPU-limited parts of the game. This test was used at a resolution of 1080p at maximum settings.
1,000 RPM Fan Test
One of the first things that we will say about the Corsair iCUE LINK TITAN II is that it is AMD-optimised. In other words, it is designed for AMD CPUs, not Intel CPUs. Given the current state of the CPU market, and how dominant AMD X3D CPUs are in the gaming space, we can see why Corsair made this move. That said, this places the TITAN II behind its predecessor on our charts. AMD-optimised clearly means sub-optimal for Intel.
1500 RPM
At 1500 RPM, we see better results, though the TITAN II remains behind its predecessor on our Intel-based test system.
Maximum Fan Speeds
At max speeds, we see similar results to before. Not a bad result, but not the best. That’s what happens when an AMD-optimised cooler is placed on an Intel-based test system.
