Corsair iCUE LINK TITAN II 360 RX LCD Review
Thermal Testing – (Intel) Cinebench R24
OC3D CPU Cooler Stress Test
We want to push CPU coolers to their limit, and that requires a workload that will place maximum load on our i5-14600K CPU. Why didn’t we choose an i7 or an i9? The simple answer is that we want to test various CPU Cooler options. If we put the hottest CPU we could in our system, only the best of the best CPU coolers would even pass our testing procedures. Since not everyone uses such a power-hungry CPU, we decided to tone the wattage and thermal loads down by using an i5-14600K. Even so, this CPU consumes a lot of power and generates a lot of heat under all-core workloads. Note that our CPU is operated with a fixed voltage to deliver higher levels of thermal consistency between CPU coolers.
For testing, we have used Cinebench R24. This is an all-core workload that places heavy strain on all available CPU cores. This load pushes CPU thermals higher than any other and does so consistently. We use Cinebench R24 for 30 minutes to see how hot our CPU gets over that time. If CPU temperatures rise to 100 degrees Celsius or over, that CPU cooler has failed our testing. This is part of the reason why there are more coolers on our higher fan RPM cooler charts. Some coolers will pass our thermal testing at higher fan RPMs but fail at lower fan RPMs.
1,000 RPM
At low fan speeds, the TITAN II doesn’t deliver strong results on our test system. While not the worst liquid cooler we have tested, this cooler does not run optimally on Intel-based CPUs. When Corsair says that this cooler is optimised for AMD CPUs, they mean it. We see much lower thermals with Corsair’s last-gen TITAN cooler on this setup.
1500 RPM
Cranking fans up to 1500 RPM delivers stronger results, but it’s far from the best. Again, this cooler is AMD optimised, so this kind of result is to be expected.
Max RPM Fan Test
At maximum fan speeds, we see similar placement on our charts. If you’re buying Corsair, get the TITAN if you use Intel CPUs. The TITAN II is for AMD CPUs. The good news is that the TITAN II RX LCD’s screen is available standalone, and you can use it with the original TITAN.
