Corsair iCUE LINK TITAN II 360 RX LCD Review
AMD Testing – A Ryzen-Optimised Design
The TITAN II runs much better on AMD-based PCs
When we started testing this CPU Cooler, we already had an AMD-powered PC (see here) with Corsair’s first-generation TITAN cooler set up. This gave us the perfect opportunity for comparative testing, as this CPU had AMD’s popular Ryzen 7 9800X3D CPU installed, and it didn’t take much to swap the coolers over.
The benefits of Corsair’s TITAN II design are most apparent at low fan RPMs. With each cooler’s fans set to 600 RPM, the TITAN II delivered thermals almost three degrees lower than the original Corsair TITAN. However, the gap narrowed at higher fan RPMs. While the difference is small in most cases, it is there. That said, the Ryzen 7 9800X3D is far from the hottest AMD CPU available, so the TITAN II’s cooling benefits would likely show up better with a more powerful Ryzen CPU like the Ryzen 9 9950X3D or Ryzen 9 9950X3D2 Dual Edition.
