Enermax Liqmaxflo 360 AIO Review
Installed
Installed
Once installed, here in our usual CPU cooler test rig, you can get a closer look at the magnetic fan that pushes air across the VRM section of your motherboard if you wish to utilise it. If you’ve got someone who likes to poke their fingers into your case there is also a branded cover available as you can see in the second of these pictures.
The VRM fan, like the main ones, has plenty of lighting patterns available to flick through.
