Fractal Design Define S2 Vision Review
Wow…Just Wow. There aren’t very many cases that come along, which when unpacked just make us stand there and stare…and stare…and stare. The Fractal Design Define S2 Vision though, is one of those cases. As you might imagine it’s based on the other cases in the Define S2 series, but with the difference that not only is the left hand side panel smoked tempered glass, but also the right side panel, the front panel, and even the roof. Add to that the case is available as the Vision Black out as we have it in the images, and the Vision RGB as seen in the video and we think you’ll begin to appreciate what an amazing looking case it is. best we stop drooling and get down to business.
Technical Specification
| Dimensions | 543x223x456 (LxWxH) |
| Material | Steel Chassis, Plastic trim, Tempered glass panels |
| Weight | 12.1kg |
| Motherboard | M-ATX, ITX ATX, EATX (up to 285mm wide) |
| 5.25″ | 0 |
| 3.5″ | 3 (shared with 2.5″) |
| 2.5″ | 8 (3 shared with 5.25″) |
| Front I/O | 1xUSB3.1 gen 2 Type C, 2xUSB3.0, Audio in/Out |
| Expansion Slots | 7 2 vertical |
| Air Cooling |
Front: 3×120/140 (3×140 included) Roof: 3×120/140 Rear: 1×120/140 (1×140 included) Base: 2×120/140 |
| Water Cooling |
Front: 120/240/360. 140/280 (max 147 mm width) Roof: 120/240/360. 140/280/420 (max 35mm component MB Height Rear: 120 Base 120/140. 240 |
| Max CPU Cooler Height | 185mm |
| Max GPU Length | 440mm |
| Max PSU Length | 300mm |
