HAVN BF 360 Flow PC Case Review
HAVN H-Series Fans
HAVN H-Series fans
Alongside their new B360 case, HAVN has launched its new H-series fans. These fans are available in single-fan and multi-fan packs, and all of them are thicker than standard 25mm thick PC fans.
For their H18 180mm fans, HAVN has created the thickest PC fans on the market, measuring 40mm thick. The H14 (140mm) and H12 (120mm) are both 30mm thick. These fans are designed to be optimal for liquid cooling radiators and for case airflow.
- H12 Single Pack £16.99 inc. VAT (Black/White)
- H12 Triple Pack £34.99 inc. VAT (Black/White)
- H14 Single Pack £18.99 inc. VAT (Black/White)
- H14 Triple Pack £39.99 inc. VAT (Black/White)
- H18 Single Pack £24.99 inc. VAT (Black)
- H18 Dual Pack £44.99 inc. VAT (Black)
HAVN has designed its fans to deliver optimal airflow and reduced noise levels. This is why the fan’s blade edges feature a waved design and its hub features air guides to give these fans a smoother airflow pattern.
HAVN’s H-series fans are constructed using a 30% glass fibre-reinforced substrate, making these fans rigid and strong under high-stress conditions. Each fan features rubber pads at each edge to minimise vibration and noise.
Each fan features a male and female fan connector for easy daisy-chaining, as well as a design that allows users to wrap cables around the fan to facilitate better cable management. Like the BF 360, HAVN’s H-series fans are well-designed and highly functional.
