MEGA Airflow! HYTE X50 PC Case Review
Meet the HYTE X50 Series
The HYTE X50 has arrived, and it promises lots of colour and tonnes of airflow
Let’s face it, most PC cases are rectangular boxes with a fairly standardised layout. It is rare for case designers to create something truly different from the norm, especially when some manufacturers are quick to copy the features of anything that is even remotely popular. HYTE isn’t copying anyone here. The X50 is a highly unique case design, offering high airflow and an aesthetic unlike anything else on the market.
What HYTE is offering here is a case with some unique engineering and a purposeful design. HYTE wanted to deliver a high-airflow case that is modern, well-crafted and visually appealing. To say the least, they have succeeded.
A big splash of colour
At launch, the HYTE X50 and X50 Air will be available in Snow White, Pitch Black, Wild Cherry, Strawberry Milk, Taro Milk, and Matcha Milk. All models will be available with either mesh side panels (X50 Air) or laminated acoustic glass side panels.
Insane manufacturing skill
What impresses us most about the Hyte X50 is how it was manufactured. When designing parts to be mass-manufactured, the standard rule of thumb is to keep it simple. Don’t do anything crazy, and make sure your part is made in a way that’s well-suited to its intended manufacturing process. With the X50, Hyte threw caution to the wind with its front panel design. They wanted as many holes as possible to achieve higher levels of airflow. That many holes in a part that will be pressed into a curve is nightmare fuel for manufacturers. Simply put, this part is begging to be torn apart during pressing. One tear and the part is ruined.
Somehow, Hyte managed to create a design that is suitable for pressing while maximising the number of airflow holes. Most manufacturers would have given up and reduced their hole count to make manufacturing simpler. Hyte tested design after design until they found one that worked.
At Computex 2025, Hyte showcased prototype designs for its X50 front panel. Below, we can see two that tore themselves apart during pressing. We also see another that had a thick, unperforated edge. Simply put, this thicker edge design would have given the X50 less breathing space for this case’s front fans. It would have also ruined the case’s aesthetic.
Hyte had a design goal, and they committed to it. That’s a clear sign that HYTE’s engineers are proper hardware enthusiasts. They didn’t do what was easy; they did the hard work to make sure that everyone got a better case in the end.
Panoramic glass, kinda
Panoramic glass, kinda? What does that mean? Yes, this case’s glass panel allows users to view their hardware from the top and side. However, the PSU cover blocks most of the top view of this case. Let’s face it, most people don’t put a window on their house and have a brick wall on the other side. That said, users of this case can easily customise this area with artwork, stickers, decals, or something else.
For modders, this area presents an opportunity to remove this section and create an SFX power supply mounting area. If you did this, users would have a great view from the X50’s top and side. Honestly, this has left us wondering why HYTE insisted on using an ATX PSU mount on this case.
Note that the glass on the X50 isn’t the standard “tempered glass” used in most PC cases. The X50 uses 4mm thick laminated acoustic glass, enhancing this case’s noise-dampening ability while providing users with a safer failure state. HYTE calls the glass in this case “shatter-proof(ish)”. The bonding layer between this case’s two glass panels ensures that your panel doesn’t shatter into a million pieces when broken. Should the worst happen, at least the cleanup will be relatively simple.
HYTE X50 VS X50 Air
While most “air” versions of PC cases deliver better thermals, that isn’t the case for the Hyte X50 Air. Its perforated side/top panel affects the X50’s airflow pattern, making it sub-optimal. The standard/glass version of the X50 delivers lower CPU and GPU thermals, as case airflow is channelled from the front and bottom to the back. This directs more airflow towards your PC’s hottest components, resulting in lower thermals.
HYTE X50 Specifications
The HYTE X50 supports motherboards up to EATX in size and ATX motherboards up to 223mm long. The case supports 10 fans in total, but ships with no fans out of the box. HYTE’s X50 has a fast 20 Gbps USB Type-C Gen 2 port on its front panel, and two additional 5 Gbps USB Type-A ports. The case measures in at 510mm x 255mm x 515mm and is available in six colours.
MSRP Pricing
HYTE says that its X50 series cases will be available starting next month (around November 6th in the UK), but pre-orders are already available from some retailers. The X50 is available with either a mesh side/top panel or a laminated acoustic glass panel. The air model is more affordable, costing £30/$40 less than the glass model. Both will deliver largely similar thermals, with the glass model delivering slightly better thermals according to HYTE’s own testing.
UK Pricing
(Hyte’s MSRP pricing for its X50/X50 Air PC cases)
