Noctua NF-12×15 Slim Fan Performance Review
NA-SAC5
The label on the simple black box informs us that what lies within is a SATA to 4pin power adapter cable. In this case we have a pair of them to play with.
And here it is, in all it’s glory, resting on a small foam rubber sheet insert we have the 300mm long NA-SACS adapter cable. If we’re honest we have to say that nice though the presentation is, it may well have cost more to make the box than the cable.
NA-FC1
Also for our delectation we have the NA-FC1 fan controller. Like the adapter cable above, it also comes in a nice simple box. Let’s hope there’s a little more inside this time.
Please tell me that’s not it! Please tell me there’s more in here than this little box with a dial on it!
And indeed there is more in here. Quite a lot more in fact. Along with the control box, which has an input and output side for the cables to attach to, there’s an NA-EC1 extension cable, an NA-SC1 Splitter cable and an NA-AC4 input cable with power supply adapter. The fan controller can be used as a conventional fan controller with a 12v feed, or in PWM mode where it will take a signal from the motherboard. In fact, the fan controller can be used as a semi automatic PWM controller with the speed dial limiting the fan speed, whilst still under PWM control. It also has a “No Stop” mode which guarantees that the fans will always turn even when set to their very lowest setting, or to a point where they might otherwise cease to rotate. All in all a clever bit of kit, and we think an essential to keep on hand.
