Raijintek ORCUS RGB 240mm AIO Preview
Today we will be looking at one of Raijintek’s latest AIO designs, the Orcus RGB, which offers a unique design and a selection of unique features, many of which are not found on more expensive all-in-one liquid coolers.
While at first glance many will dismiss the Raijintek ORCUS as “just another AIO water cooler”, it is obvious that the company is attempting to break the standard liquid cooling mould. First off the pump is not integrated into the RGB water block, unlike designs from Coolit or Asetek, and is instead mounted their pump close to the radiator on the device’s tubing, where vibrations will not transfer to other components, dampening the effects of pump vibration.
The model we have also featured two 120mm RGB fans and an RGB controller, which can be integrated into your system’s existing RGB setup using 4-pin RGB cables or controlled using a wireless remote.
We can also see that Raijintek offers users a bottle of coolant, allowing them to top up their cooler if any fluid is lost over time to evaporation, making the Orcus one of the only refillable AIOs on the market.
Two Options – The ORCUS Core or the ORCUS RGB
Raijintek’s Orcus cooler ships in two forms, Core and RGB, with the core coming without any fans while the RGB offers two (you guessed it) RGB illuminated 120mm fans. The Core allows users to utilise their existing fans with this unit and gives buyers the opportunity to save a little money at the time of purchase, making it the value option for anyone who has any 120mm fans lying around.
Both units come with the same RGB cooling block, which offers support for every major CPU socket from both AMD and Intel, aside from TR4/X399.
