Raijintek Morpheus GPU Cooler Review
Although only established in 2013 Raijintek have been quick to release products to market. Today we’re going to be taking a look at the Morpheus GPU cooler. The cognoscenti amongst you will already know that sometimes a GPUs stock cooler just isn’t good enough to provide the amount of cooling required to tame the temps of modern Graphics cards, let alone at noise levels that don’t leave your ears bleeding. In looking at the R9 290, and 290X and seen what third party manufacturers such as MSI, Asus and PowerColor are capable off in providing cards with coolers that can unleash some of the headroom in the chip, other wise hobbled by the wheezy AMD reference coolers, we thought it time we looked at what after market coolers were capable of. Over the next few weeks we will be looking at various options, but first to get the OC3D treatment is the new Morpheus cooler from Raijintek. As you’ll see when you get into the meat of the review it’s certainly a big bugger but as we know, large heat sinks don’t always translate into low temps.
Technical Specification
| Product Name | MORPHEUS |
| Product Number | 0R100006 |
| Dimension [WxDxH] | 254x98x44 mm |
| Weight | 515 g [Heat Sink Only] |
| Thermal Resistance | 0.135 °C/W [With Raijintek 12025 fan*2] |
| Heat Sink |
Base Material Mirror copper base Fin Material Aluminum Alloy; Solder assembly |
| Heat-pipe | Φ6mm 12 pcs |
| Heat-sink for RAM & VRM |
A type: 9pcs 13.4(W) x 11(H) x 15(D) mm B type: 9pcs 13.4(W) x 5(H) x 15(D) mm C type: 6pcs 5.9(W) x 11(H) x 20(D) mm VRM type 28(W) x 18.5(H) x 94(D) mm |
| AMD® |
Hawaii chip: R9 290/290x Curacao chip: HD 7850?7870 xt; R9 270/270x |
| nVIDIA® GTX Series | 650, 650Ti, 660, 660Ti, 680, 760, 770, 780, 780Ti |
Key Features
Cooling capacity up to 360 watts TDP
12 pcs copper heat-pipes and 129 pcs fins for efficient heat dissipation
24pcs heat-sink for RAM & 1 big heat-sink for VRM
High compatibility with modern & future VGA cards
Thermal adhesive to lower RAM and VRM temperature significantly and assure proper bond
Compatible with AMD Hawaii chip (R9 290/290x) and Curacao chip (HD 7850, 7870 xt; R9 270/270x)
Compatible with nVIDIA GTX Series Chip: 650, 650Ti, 660, 660Ti, 680, 760, 770, 780, 780Ti
Supports two 120mm fans (4 fan clips in the box)
Whole heat-sink nickel plated
