Silverstone Cooler: Nitrogen NT03
Silverstone are well known for their Top-Class cases and solid power supplies. Recently Silverstone has started to dabble in the world of processor cooling.
The Nitrogen series (or NT Series) are a series of coolers of various shapes and sizes. I am taking a look at the smallest of their coolers: the NT03. Will it’s diminutive size hold it back?
Packaging
Silverstone generally do a top job of their packaging and the NT03 is no exception. The outside of the box contains good product information and has a nice window in it to allow you to see what your buying.
What you get
The NT03 comes with a lot of extra parts that make your life a little bit easier when fixing it together.
There is a fan extension cable for putting both the fans on one fan header and a retention bracket for both AMD and Intel. Silverstone have also included some cooling solution in with the package that looks to be some kind of ceramique-like thermal paste.
Let’s see if the cooler works as good as it is packaged…
