Silverstone Grandia GD02-MT Case
Packaging & Contents
The case comes in a sturdy cardboard box, which is adorned with images of the case contained within. There is quite a bit of information printed on the box with all the major selling points being covered. On the top of the box is a picture of the case both in the black and aluminium finish, with some text highlighting the major features. The sides of the boxes give the specifications and and some short intro text.
Upon opening the box, we found the contents to be well secured with foam and cardboard inserts. Under the top layer of card was the case, which I thought was wrapped in some black material.
Once I removed the case from the box I realised that the material was in fact a drawstring bag. I’m not sure what use it could have after the case has been used, but it keeps the case in tip top condition during transit. Silverstone have also protected the front panel and LCD screen with a moulded plastic cover.
Within the outer box was two smaller boxes. In one there was the accessories, and within the other was the remote control. We shall discuss the remote control further into the review. The accessories were as follows:
- Driver CD ROM with iMon Software
- Installation guide
- Motherboard, PSU, HD, and CD/DVD screws
- Motherboard stand offs
- Allen key for top panel bolts
- Slim Optical drive adapter & screws
- 3pin to molex power adapter
- 2 cable ties
All in all, the packaging was more than adequate and the box would have to be thrown around alot for the contents to be damaged. As LCD screens can be quite easily damaged, it was good to see that Silverstone had taken some consideration into protecting it during transit.
On the next page, we take a look at the case externals.
