ASUS ROG Crosshair VIII Formula X570 Preview
Wi-Fi and Lighting
The ASUS Crosshair VIII Formula is equipped with Intel Wi-Fi 6, which is based upon the 802.11ax codec but in a 2×2 format that allows for greater bandwidth if you have suitably compatible devices. Curiously the Intel specifications for this particular Wi-Fi 6 list it as 802.11ac, but ASUS list it as 802.11ax. Hopefully it’s the latter, although both are still capable of saturating the bandwidth of nearly any current hardware on the market. You can even see two of the compatible ASUS routers, should you want to go all in on the Tapei company.
Lastly a quick look at the AURA Sync RGB lighting equipped on the Crosshair. Whilst you bask in its loveliness, let us know your thoughts on the ASUS ROG Crosshair VIII Formula on the OC3D Forums.
Video
