ASUS TRX40 Prime Pro Review
Geekbench
Geekbench tests the single and multi-threaded performance of your system and is a good indicator of any weak spots, particularly if you’re overclocking. Remember at stock the AGESA update improves the single core performance automatically, which an overclock overrides hence the disparity between those two scores.
