DFI X58 T3eH8 Ultra Motherboard
The DFI X58 T3eH8 is the perfect evolution of the X48 derivative. From the outset the motherboard has raised the bar for all other boards to follow.
The packaging is near perfect and while I would have liked to have seen a change in colour scheme to distinguish the new board from its stablemate no one can deny it's certainly an eye catching motherboard, especially if you are a fan of UV lighting.
The layout is excellent with all the SATA ports sat at right angles to the PCB preventing any interference to over sized GPU's. Speaking GPU's, this is only the second board we have tested that would allow the use of 3 dual slot GPU's in either SLI or CrossfireX configuration but  that does present a problem. Unfortunately, as the sound card would take up one of these slots on the backplate  there would be no space (or indeed no extra PCI/e slot) to have any extra expansion cards.
The motherboard cooling is nothing short of exceptional and with a huge range of BIOS options, including extremely high voltages available to the end user, that cooling will certainly come in useful. With typical DFI support, BIOS updates should come thick and fast and should a BIOS update become corrupt the ingenious removable BIOS chip design will cut down on costs for returning the board. Which is a good thing as the initial outlay for the board will certainly dent anyones bank balance.
Costing close to the £300 mark, the Ultra version is the highest motherboard on test. While it is also the highest performing board I do have some concerns if it is actually worth the extra outlay. For the average user the DFI offers little more than aesthetics, and the Gigabyte UD5 which weighs in a lot cheaper can do everything the DFI can do. However, if you are looking for the absolute ultimate in performance then the pendulum swings back in the DFI's favour and for that reason I have no hesitation in awarding the DFI X58 T3eH8 Ultra our distinguished Performance award.
The Good
- Extreme overclocking
- Audacious cooling
- Amazing looks
The Mediocre
- Some BIOS options could be more user friendly
- Power consumption at load was highest on test
- Price
The Bad
- Nothing to report
Thanks to DFI for providing the X58 T3eH8 Ultra motherboard for todays review.  Please discuss in our forums.
«Prev 1 2 3 4 5 6 7 8 9 10 11 12 13 Next»
29-01-2009, 14:45:57
VonBlade
It's nice to know some things never change.
Amazing layout? Check.
Bulletproof? Check.
Incomprehensible BIOS options? Must be a DFI
Some great clocks coming out of that. Agree that the current high-end X58s are way too steep. Although the high-end 775 stuff was eye-watering too.
Thanks for the review.Quote
29-01-2009, 14:46:49
Kerotan
Just spotted a typo:
while at first appearance appears very thick is that that daunting once you realise it is a multi language manual.
Probably wanna replace one of the "thats" with "not". Made for an awesome read though- day I can afford kit like this is the day I win the lottery lol.Quote
29-01-2009, 15:03:02
JN
Sounds like he was overcome by the 'Chinglish' manual.Quote
29-01-2009, 15:48:48
soapsupah
its an amazing mobo, it looks pretty good, it has a lot of good points but i still dont know its price, also the asus / msi board results were as good as the DFI mobo, and sometimes even better and i expected more from it afterall DFI is pretty famous, but still its a great mobo Quote
29-01-2009, 19:42:09
w3bbo
Although the results showed the boards to be fairly even (they are afterall all based on the same chipset and run at the same settings), when scoring the boards there are many more points to consider.
The DFI board is not a board to run at stock settings, it isn't designed to do that, anyone who buys this board for that is only after e-peen glory and not using the board for what it was intended for - overclocking. In this area it excels. Therefore DFI have completed what they set out to do. The price they charge reflects the niche market they are aiming for. After all Lamborghinis arn't exactly in the same marketplace or have the same customer in mind as Diatsu.
If you want a board that covers all bases then the Gigabyte board, for me at least, is the better board.
For hassle free 'it just works', reliability then look no further than the Asus P6T.
The MSI, while not a bad board by any stretch of the imagination, offers nothing over the others for the price they are asking.Quote
