DFI X58 T3eH8 Ultra Motherboard
Multimedia/Encoding
SiSoftware Sandra (the System ANalyser, Diagnostic and Reporting Assistant) is an information & diagnostic utility capable of benchmarking the performance of individual components inside a PC. Each of the benchmarks below were run a total of five times with the highest and lowest scores being discarded and an average being calculated from the remaining three.
ViMark is the latest addition to the OC3D motherboard testing process and a relatively new benchmarking application in general. Designed to take the inaccuracies and guesswork out of measuring the time taken to encode video files, ViMark produces easily comparable and consistent results for encoding raw video into Windows Media, Quicktime, AVI and Gif formats. As always, a total of 5 benchmark runs were performed with the highest and lowest scores removed and an average calculated from the remaining 3 scores.
7-Zip is an open source Winzip-style file compression utility that has the ability to compress and decompress many file formats including its own .7z compression scheme. 7-Zip also comes complete with its own benchmarking utility for gauging the compression and decompression speed of the system that it is installed on.
Results Observations
Sorry guys, but again there is just nothing to choose between the boards, certainly not by any significant margin. Sandra showed a slight weakness on behalf of the DFI but nothing too drastic. With all the boards on test today performing pretty much equal it is certainly going to be hard to formulate a conclusion based on the results thus far.
Let's move on to our 3D Benchmarks...
«Prev 1 2 3 4 5 6 7 8 9 10 11 12 13 Next»
29-01-2009, 14:45:57
VonBlade
It's nice to know some things never change.
Amazing layout? Check.
Bulletproof? Check.
Incomprehensible BIOS options? Must be a DFI
Some great clocks coming out of that. Agree that the current high-end X58s are way too steep. Although the high-end 775 stuff was eye-watering too.
Thanks for the review.Quote
29-01-2009, 14:46:49
Kerotan
Just spotted a typo:
while at first appearance appears very thick is that that daunting once you realise it is a multi language manual.
Probably wanna replace one of the "thats" with "not". Made for an awesome read though- day I can afford kit like this is the day I win the lottery lol.Quote
29-01-2009, 15:03:02
JN
Sounds like he was overcome by the 'Chinglish' manual.Quote
29-01-2009, 15:48:48
soapsupah
its an amazing mobo, it looks pretty good, it has a lot of good points but i still dont know its price, also the asus / msi board results were as good as the DFI mobo, and sometimes even better and i expected more from it afterall DFI is pretty famous, but still its a great mobo Quote
29-01-2009, 19:42:09
w3bbo
Although the results showed the boards to be fairly even (they are afterall all based on the same chipset and run at the same settings), when scoring the boards there are many more points to consider.
The DFI board is not a board to run at stock settings, it isn't designed to do that, anyone who buys this board for that is only after e-peen glory and not using the board for what it was intended for - overclocking. In this area it excels. Therefore DFI have completed what they set out to do. The price they charge reflects the niche market they are aiming for. After all Lamborghinis arn't exactly in the same marketplace or have the same customer in mind as Diatsu.
If you want a board that covers all bases then the Gigabyte board, for me at least, is the better board.
For hassle free 'it just works', reliability then look no further than the Asus P6T.
The MSI, while not a bad board by any stretch of the imagination, offers nothing over the others for the price they are asking.Quote
