Gigabyte B550I Aorus Pro AX ITX Review
Geekbench
Geekbench tests the single and multi-threaded performance of your system and is a good indicator of any weak spots, particularly if you’re overclocking. It’s also a good demonstration of how well the AMD single threaded boost performance works at stock.
