Gigabyte B550I Aorus Pro AX ITX Review
Test Setup
As well as the B550 motherboards we’re also including our X570 motherboards in our graphs today, just to demonstrate how little the ‘lesser’ AMD Chipset is giving up compared to its bigger brother. Perfect if you’re on a tight budget.
AMD Ryzen 9 3900X
G.Skill Trident Z 3600 MHz
Corsair Vengeance RGB 4600 MHz
Corsair MP500 M.2 – OS Drive
Aorus PCIE4 NVME – Storage Speed Tests
Nvidia RTX 2080Ti
Corsair HX1000i
Corsair H150i
Corsair ML Fans
Overclocking
If you worried that the small form factor would lead to small overclocks then the use of 90A power stages should have assuaged those doubts, but if you prefer your evidence a little more concrete then just like the ATX Aorus Pro and Master the little ITX pumps out 4.4 GHz across all twelve cores of our Ryzen 9 3900X.
