Gigabyte X570i Auros Pro WiFi ITX Preview
Up Close
We never grow tired of the size of ITX motherboard boxes, or indeed the motherboards themselves. There is something about the combination of having a product which simultaneously can match a massive system in performance terms but yet do so in such a compact format that it also should spark your creativity when it comes to finding a case. After all, if the dimensions are significantly reduced then the non-standard cases that are available to you are almost limitless.
We will try not to comment again about how small an ITX motherboard is. It is though. One thing the Gigabyte X570 I Aorus Pro does that we’re grateful for is answering a lot of questions. Naturally when a new product is launched we are learning what is and isn’t possible or necessary and when we have so many on hand as we do right now then certain elements form in our mind as certainties.
For one of those questions answered we postulated as to whether the 4+8 pin CPU arrangement was standard equipment. Apparently not. The Gigabyte ITX has just the one 8 pin 12V CPU input. Maybe there is a CPU threshold you can’t cross (such as the aforementioned Ryzen 9 3xxx CPUs) or maybe Gigabyte just assume most people will be running a less power hungry model in their new purchase. We also have one
Normally we bemoan the inclusion of vertical SATA ports, but the ITX form factor is such that it is always an understandable compromise. Because each picture covers an awful lot of the acreage of the PCB, and because on the smaller ITX PCB there is much less stuff to talk about in general, it’s worth just appreciating the carefulness of the designers in making sure there is a place for everything and everything is in its place. It reminds us of a ship’s cabin or airplane bathroom. An absolute exercise in careful planning. We bet the designers were amazing at Tetris.
The other fan header of the two available to you on the Gigabyte X570 I Aorus Pro WiFi is snuck into the bottom right just next to the DIMM slot latch. We’re also pleased to see that Gigabyte have reinforced the PCI Express 4.0 slot. When it’s so near to the edge of the PCB this reinforcement is even more important than it is on the larger form factor. Anything that can stabilise your graphics card whilst also providing longevity to your foundation has to be a good thing.
Both of the DIMM slots are reinforced whilst snuck in the gap between the rightmost slot and the USB front panel header is the RGB LED strip header for the RGB Fusion lighting.
Throughout our time with the X570 motherboards it’s been clear that the PCI Express 4.0 needs a fair amount of active cooling to ensure the smoothest, fastest operation even under heavy loading. Naturally with a much smaller footprint upon which to work their design magic Gigabyte have brought a clever solution of combining the M.2 heat spreader with the chipset cooler into one homogenous whole. They’ve even managed to give it a little design flair by the inclusion of a shiny Aorus head against the brushed background. Engineering people are very smart at solving problems.
Squeezed into the left hand side of the X570 I Aorus is the front panel audio – long cables a must – as well as a system fan header and the CMOS Clear jumper. We don’t know how small your fingers are but we think we’d require tweezers. Of course if you’re anything like us you could just stick a screwdriver to bridge the gap. Of course we don’t remotely recommend it, just it might prove useful in tight spaces.
Video
Let us know your thoughts on the OC3D Forums and remember to come back for our full review on launch day. Yes we’re busy.
