NZXT N7 B650E
Up Close Continued
NZXT N7 B650E
Up Close Continued
USB 3.2 Gen2 Type-C front panel headers are ever more important as so many of our mobile devices use Type-C connectivity.
NZXT N7 B650E
Should your chassis still only support Type-A front panel USB then you're well catered to with two headers bracketing the 4 SATA ports.
NZXT N7 B650E
The bottom right edge has a host of options. From right to left we have front panel connectors that attach your case to the heart of your rig, followed by onboard power and reset buttons, perfect for testing your build before tidying all your cables away. Two more NZXT RGB headers follow, with three system fans after those.
NZXT N7 B650E
Three USB 2 headers ensure all of your other controlling devices have a home without you needing to buy an extension bracket. After those come two ARGB headers of the more familiar type, should you not have NZXT devices for other lighting.
NZXT N7 B650E
The PCIe 5.0 M.2 heatsink is a chunky monkey, and a perfect encapsulation of the careful design behind the N7. The heatsink matches that used on the VRMs, whilst the white cover blends it perfectly into the motherboard itself.
NZXT N7 B650E
Taking the cover off you can see the three M.2 slots - one PCIe 5 and two PCIe 4 - with the Bluetooth 5.2 and WiFi 6E controller sitting in the middle.
NZXT N7 B650E
Beneath the familiar NZXT heatsink and backplate arrangement beats a very impressive 16+2+1 power phase design with 90A Smart Power Stage, ensuring that even if you want to run a Ryzen 9 7950X the N7 B650E has enough power to keep things running smoothly.
NZXT N7 B650E
NZXT deserve a lot of credit for sticking with their design philosophy rather than changing things up for changes sake. Available in both black and white models for £309.98, it's an affordable way of getting the latest AMD platform into your system.
Discuss the NZXT N7 B650E in our OC3D Forums.
«Prev 1 2 3 Next»
