ASUS EAH6970 Review
Test Setup and Overclocking
Published: 21st December 2010 | Source: ASUS | Price: £306.10 |
Test Setup
Slightly different to our 1366 setup with the i7-950 we wanted to see how well the HD6970 performed elsewhere and so have put it in our LGA1156 rig. Not only does this give us a chance to get a wider range of results, but also could be the swansong for our i7-870 with the forthcoming P67 boards.
Intel i7-870 @ 4GHz
4GB G.Skill Trident @ 2000MHz
Gigabyte P55 UD4
Thermalright MUX-120
ASUS HD6970EAH
Cougar CM1000 1KW PSU
Windows 7 64-Bit
Overclocking
When we tested the HD6970 recently we found their was a block at 950MHz when you hit the top of the slider and so couldn't go any further.
We waited with anticipation for the Voltage Tweak BIOS included with ASUS graphics cards to see if this would improve the situation and allow us to break through the 1GHz barrier. However the rather odd thing is that even with the ASUS SmartDoctor the limit was still set at 950MHz. So the superb BIOS had nothing to do but twiddle its thumbs.
any chance of a dump please Bryan?
[edit] did you try the "EnableUnofficialOverclocking" feature of Afterburner to get past the limitations of Catalyst Control Center?Quote
man, i need some more info!
1- what is a the max voltage in smart doctor?
2- why didn't you use MSI's AfterBurner for OC;ing? ppl are getting higher clocks with that, max i saw @ stock voltages was 980mhz Core, so maybe up the voltage using Smartdoctor and get to 1Ghz (World FIRST!!) using Afterburner??
3-What are the temps? this one has aluminum cover, wanna see how much this one is cooler! before and after OC please!
i know am asking alot, but am barely holding back waiting for those to be in stock (USA), if no diff than other ones (plastic cover) my wait is over! thanx in advance!
EDIT:damn 19 sec diff pyro!
But looking at it from my pov, I've seen that issue with using an overclocking tool before. You ramp the slider as high as it'll go and you feel you could take it further - and it just won't allow it. It happened
to me recently using afterburner on a 8400 (which is besides the point), but you feel the 'tool' is being told the up/low limits. Perhaps the bios is the key.
If it were mine (I mean donate to me to play with), I'd delve into the bios fiddling menu like atitool/afterburner has and try and massage the limits. From memory tho, if the tool doesn't know the card's bios, it will limit what you can do. I'd still fiddle with it tho.
This is besides the point tho. Off the shelf, something still aint right to me.
Voltage tweak and a oc limit ? Nah, definitely not.
I hate to harp on about it, but those bios versions from the ref card and this would be interesting. I'm going to see if there's any revisions coming out in the future too.Quote
