Gigabyte GTX750Ti Windforce Review
So far we’ve looked at a handful of GTX750Ti’s and found them all to be extremely close in performance. Such is the consistency of the nVidia GPU manufacturing that it’s hard to buy a bad one.
That does mean that the same applies at the other end of the scale, and so it is on very fine margins that decisions between particular brands and models of GTX750Ti are made.
With the Gigabyte Windforce version in our sweaty hands we find out if this has enough to offer to bring it above the throng. After all it’s from a very reputable manufacturer and, as we’ll see on the next page, has enough cooling capacity to keep a far more powerful card feeling frosty.
Technical Specifications
| Chipset | GeForce GTX 750Ti |
| Memory Clock | 5400 MHz |
| Process Technology | 28 nm |
| Memory Size | 2048MB |
| Memory Bus | 128 bit |
| Core Clock | Base:1033MHz Boost:1111MHz (Standard- Base:1020MHz Boost:1085MHz) |
| Card Bus | PCI-E 3.0 |
| Memory Type | GDDR5 |
| DirectX | 11.2 |
| OpenGL | 4.4 |
| PCB Form | ATX |
| Digital max resolution | 4096 X 2160(via 2 HDMI) |
| Analog max resolution | 2048 x 1536 |
| Multi-view | 4 |
| I/O | Dual-link DVI-I*1/DVI-D*1/HDMI*2 |
| Card size | L=204mm , W=144 mm, H=42mm |
| Power requirement | 400W |
