MSI GTX1060 ITX and GTX1050 Ti SFF – RushKit
The half-height GTX 1050Ti will come with the same base/boost clock speeds as Nvidia’s reference model, with the GTX 1060 6GB Aero ITX coming with a mild factory overclock. The GTX 1050Ti does not require any external power connections, so any PC with a PCIe 16x lane should have enough power to use the GPU to its fullest potential.
| Nvidia GTX 1050 Ti | MSI GTX 1050Ti 4GB SFF | Nvidia GTX 1060 6GB | MSI GTX 1060 Aero ITX OC | |
| CUDA Cores | 768 | 768 | 1280 | 1280 |
| Base Clock Speeds | 1290MHz | 1290MHz | 1506MHz | 1544MHz |
| Boost Clock Speeds | 1392MHz | 1392MHz | 1708MHz | 1759MHz |
| Memory Fequency | 7008MHz | 7008MHz | 8008MHz | 8008MHz |
| Memory Bus | 128-bit | 128-bit | 192-bit | 192-bit |
| Memory Cappacity | 4GB | 4GB | 6GB | 6GB |
| Power Connections | PCI Only | PCI only | 1x 6-pin | 1x 6-pin |
What these two GPUs provide their users with is a lot of utility, whether you want to upgrade a small server, office PC or HTPC with a gaming GPU, or upgrade an ageing pre-built system with some much-needed GPU horsepower.
These GPUs are designed to place gaming graphics into systems that do not support traditional GPU form factors. Despite their small size these GPUs are both cool and quiet and are certainly not going to overpower their users with high noise levels.
MSI are also offering a GTX 1050 version of their half-height GTX 1050Ti, with both GTX 1060 3GB and GTX 1070 8GB versions of their new Aero ITX GPU designs.
Right now MSI’s GTX 1050/1050Ti SFF GPUs are already available to purchase at Overclockers UK for prices of £119.99 and £149.99 respectively. MSI’s Aero ITX series of GPU are expected to hit retail shelves within the next few weeks.
You can join the discussion on MSI’s new GTX 1050 Ti SFF and GTX 1060 6GB Aero ITX on the OC3D Forums.
