PNY GTX580 Liquid Cooled Review
Crysis Warhead
Something strange happens with the mere Gamer settings in Crysis Warhead. Although the average frame-rate is rock solid both at stock and overclocked, the minimum frame rate really takes a pounding. Even weirder the, admittedly excellent, GTX560Ti gives us the same result. So let’s turn it all up to eleven.
Enthusiast
Things return to normal when the image quality is upped as high as it can go. In fact the overclocked PNY is up there with a standard GTX590.
