Quantum Break PC Performance Review
1080p Testing with the GTX 960 and R9 380
One thing that we need to remember with UWP app is that V-Sync is enabled by default, meaning that V-Sync is always turned on, which results in the minimum results here typically sitting at around 30FPS.
With V-Sync turned on the game will usually run at 60FPS or 30FPS, with lower framerates playing at some stranger framerates, but at 1080p both the GTX 960 and the R9 380 are able to play the game with playable framerates that are at 60FPS for the most part at low settings.
When it comes to minimum framerates we look at two different results, first the 1% minimum framerate and the 0.1% minimum framerate. These are percentile data that are based on the frametimes we achieved during our benchmarking session, meaning that 99% of the time the framerate is above the 1% minimum framerate and that 99.9% of the time it is above the 0.1% minimum framerate.
With V-Sync being forced on this can leave a huge difference between the 1% and the 0.1% minimum framerates, meaning that the game can have some highly significant micro-shutters that can occur sometimes during gameplay.
With the game looking pretty horrible at below medium settings many players may want to drop their resolution to get a balance between good visual quality and a stable framerate with lower end GPUs. Regardless users should not need to go as low as the Xbox One version's resolution of 900p or turn off AA in order to get playable framerates at medium settings.
In general, here the GTX 960 and R9 380 perform very similarly, with the AMD GPU generally having some lower framerate dips but better performance on average. Hopefully these low minimum framerates that happen on the R9 380 can be fixed with a driver update or game patch.
«Prev 1 2 3 4 5 6 7 8 9 10 11 Next»
07-04-2016, 13:54:34
AngryGoldfish
For every GTA V, Shadow of Mordor, and Mad Max, with great gameplay, limited bugs and superb performance scaling, there is a Syndicate, Quantum Break, and Gears of War.Quote
07-04-2016, 16:36:19
Mysterae
Nice write up.
I'm convinced this is a game with a couple of purposes. Firstly, to get Xbone users to try it on their computers as well, to either convince them that PC's are crap or to show them what's better on the PC. They failed at the latter.
Secondly, it's an experiment with UWP on the masses, to see if we will swallow this ****.
You have an important typo on the third page that gave me a glimmer of hope, but alas it's not true - ".. which is a shame since this game has now SLI or Crossfire support".Quote
08-04-2016, 06:10:35
WYP
Originally Posted by Mysterae View Post
Nice write up.
Typo fixed, thanks for the spot.
A lot of extra work went into this one, especially when it came to getting benchmarking data. I like the idea of percentile based framerate data, which is something that I will be looking more into for the future.Quote
08-04-2016, 07:00:39
SimplexPL
While there has been a lot of talk on the internet about the "terrible" PC performance of Quantum Break I can say that these reports have been exaggerated
Sadly on my system I was unable to get the game to run at a solid 60FPS, regardless of the GPU that I used (...) which is a very strange prospect given that I was playing Quantum Break from an SSD on a system with an overclocked i7 6700K CPU and 16GB of 3200MHz DDR4 memory.
So you were unable to run at solid 60fps at 1080p (which is effectively 720p if NeoGAF is to be believed) at lowest settings on "overclocked i7 6700K CPU and 16GB of 3200MHz DDR4 memory" and a 980Ti/Fury, yet reports that the game runs terribly are "exaggerated"?
This game runs terribly, period.
Not being able to sustain 60fps at the lowest graphical settings at 1080p (reprojected 720p) on a fastest possible CPU, memory and GPU means, that the talk on the internet about the "terrible" PC performance is accurate, not exaggerated. What is the last AAA game that run that badly?Quote
08-04-2016, 10:05:08
Primey
What a bloody mess of a gameQuote
