Zotac GTX590 SLI 5760×1080 Nvidia Surround Review
If you’re a regular reader, and if not why not, you’ll have been awaiting today’s review.
After dipping our metaphorical toe in the triple-screen water with the HIS HD6990, today we’re back with a nVidia offering in the form of the Zotac GTX590.
Of course we could just review a single card, but as Zotac kindly offered to lend us two so we could run in SLI we’ll be testing in both forms today.
Technical Specifications
Popping along to the Zotac website we find the specifications for the GTX590. Unlike the AMD solution the nVidia multi-screen setup is based off of 3x DVI connections rather than mini display ports.
Otherwise it’s a standard reference design card.
| Model | ZT-50501-10P |
| Cooler Type | Fan (Dual Slot) |
| Core Clock | 607 MHz |
| Core Processors | 1024 (2 x 512) Stream Processors |
| Dimensions | 4.376in x 11in – 111.15mm x 279.4mm |
| DirectX | DirectX 11 |
| Dual-Link DVI Supported | Yes |
| DVI | 3 |
| GPU | GeForce GTX 590 |
| HDCP Ready | Yes |
| HDMI | 1 x Mini-HDMI 1.4 |
| Interface | PCI Express 2.0 x 16 (Compatible with 1.1) |
| Max Resolution | 2560 x 1600 |
| Memory Clock | 3414 MHz |
| Memory Size | 3072MB (2 x 1536MB) |
| Memory Interface | 768-bit (2 x 384-bit) |
| Memory Type | GDDR5 |
| Recommended Power Supply Wattage | 700-Watt |
| Package Contents | 1 x DVI-to-HDMI cable 1 x DVI-to-VGA adapter 2 x Dual 6-pin PCIe to 8-pin PCIe power adapter 1 x Assassin’s Creed®: Brotherhood game bundle 1 x Driver Disk 1 x ZOTAC Boost software bundle 1 x User manual |
| RAMDAC | 400 MHz |
| SLI Supported | Yes |
| Weight | 5.3500 lb |
| Warranty | 2-Year Standard Warranty; Limited Lifetime Extended Warranty |
Time to have a look at the card and bundle.
