Cooler Master SK621 Wireless Keyboard Review
It isn’t giving away any secrets to say that we’re big fans of the USB protocol here at OC3D. Having spent most of our youth configuring devices through complicated connections the ability to just plug something in and have it work absolutely revolutionised the technology industry. You need to look no further than all of your smart devices, or consoles, or… well anything to discover how much of a benefit USB has been.
What has that to do with the Cooler Master SK621?
A similarly brilliant piece of problem solving comes in the form of Bluetooth, named after King of Denmark and Norway, Harald Bluetooth. Just like nearly everything you own has USB options of some type, so if there is a wireless mode then it is probably Bluetooth that provides it. This ubiquity allows you to connect all sorts of hardware to a huge array of other hardware, in a seamless style. Want to listen to your smart television or phone through headphones? Bluetooth. Want to use your PS4 pad on the PC? Bluetooth. Want to be able to type on your smart device without enduring the hopelessly slow “one letter at a time” on screen keyboard? Try the Bluetooth-equipped Cooler Master SK621.
A compact design that doesn’t lack for high quality features, the Cooler Master SK621 is the perfect solution for inputs without needing you to lug a full sized keyboard around with you. Let’s take a look.
Technical Specifications
