Corsair Clipper Pro Mini 60 Keyboard Review
Undoubtedly the biggest (ha) thing you notice about the Corsair Clipper Pro Mini 60 is the compact size. Even in a world of TKL or 80% keyboards, it’s tiny. If you’ve got limited desk space, or often go out gaming, the compact size is a boon. It’s available in both white and black. Do note that the grey keys you can see on our review sample remain that colour on the black one. Worth noting if you prefer a single colour aesthetic.
Although there aren’t many keys to type on, they are very nice. A magnetic switch always takes a bit of getting used to. Fortunately the software allows you to tune everything about how a key activates. Whether you’ve got a feather touch or type like you’ve got anvils for hands, there is a setting that will enable you to make the most of the Clipper. There are many layers of sound cushioning built in too. The combination of hall-effect switches and the damping makes for a quiet typing experience. The 8000Hz polling rate makes for a quick typing experience too.
Within the software, and again we have to say we don’t understand why the Clipper didn’t work in iCUE, there are loads of customisation options. We like the way that the Rapid Trigger cancels a key the moment you start to lift it. We can’t be the only people who died because we changed our mind mid-lift and it took too long to re-engage the press. If you tire of holding a key Tap Lock lets you toggle things on and off with a hold. Fantastic for your aching fingers during those marathon sessions. Especially if hold toggle isn’t available for that action in the game settings.
With so few keys available, both Smart Tap and Multi-Action help expand your gaming palette. The first gives you two keys depending upon if you short or long press the key. Whilst the latter will really test the control you have over how much each finger presses a key.
If you’re the type of person who can get a bit clumsy, then you’ll appreciate the IP57 certification that gives water and dust resistance. Heck you could accidentally drop it in water and, as long as you rescued it quickly and gave it plenty of time to dry out, all should still be well.
The Corsair Clipper Pro Mini 60 is perfect if you desire full control over your keyboard, but also want it to fit in almost the palm of your hand. The ultimate in customisation wins it the OC3D Gamers Choice Award.
Discuss the Corsair Clipper Pro Mini 60 in our OC3D Forums
