Corsair M55 RGB Pro Review
Software
The Corsair iCUE software is one of the best packages around with clearly labelled functions and plenty of powerful options should you wish to take the time to explore them all. With just the single lighting zone there isn’t much you can do with crazy effects, but the macro editor is as powerful as any on the market, the DPI options are plentiful and can have custom lighting colours to make it easy to see which you’re using.
