Corsair Strafe RGB MK2 Silent Mechanical Gaming Keyboard
Software
The Corsair Utility Engine (CUE) software can be as powerful as you wish, or as simple as you need. If you just want to set the keyboard up to be a single colour in harmony with your system or clan then it’s a matter of moments. If, on the other hand, you want to take the time to set up complicated configurations that take into account cooldowns timings on your game, or toggle between different colours when pressed, or whatever your mind can come up with, then the CUE software wont be the limiting factor. The very latest version of this software – the iCUE – allows you to control your entire system, should you have plenty of Corsair RGB gear inside your case.
