Icemat 2nd Edition Mouse Mat
Aesthetics
The Icemat 2nd Edition itself, it has to be said looks great. It is extremely simplistic, merely a sheet of clear glass, sat on top of a coloured sheet, which gives the mat a frosted tint.
The Icemat logo and website are in the bottom right corner, printed onto this coloured sheet. Since these are not printed on the top pane of glass there is no rough surface anywhere on the mat, contrary to others on the market.
The underside of the mat has 6 rubber spheres, one in each corner and 2 in the middle. These acts as grips, which stop the mouse mat from moving around on your desk, which can be a problem with other mats on the market.
However, it can be said that they could do a better job. Whilst just moving your mouse will not move the mat itself, putting any forward pressure onto the mat with your wrist will. The circular shape of the grips just does not put enough surface area onto the desk, and you will find the mat continually slipping forward if you rest your wrist or arm on it.
The Icemat 2nd Edition, being made of glass is also quite heavy. Whilst this shouldn’t be a problem as it will most likely spend all of its time glued to your desk, it is worth noting that taking this mat to a LAN party or to a friend’s might not be too practical, considering its fragility as well as its weight.
Final things worth noting on aesthetics are the rounded corners, which are a nice touch and make the mat look modern. Also, the mat is just under a centimeter deep, and the rubber grips create a gap of roughly 2mm from your desk. This can become a minor annoyance, as pieces of paper and very thin objects tend to find their way underneath the Icemat.
Next we will take a look at how the Icemat 2nd Edition performs in practical use.
