MSI Clutch GM30 Gaming Mouse
Lighting
The lighting on the Clutch GM30 is far better than you would expect for a model at the lower end of the MSI Clutch range. Colours are both richly saturated and uniform, whilst the U-shaped light around the DPI cycle button certainly grabs your attention. As always we’ve tried to cover most of the main colours you’re likely to choose, and we think whichever is your preference you will be pleased with the result.
