Steelseries Rival 600 Mouse Review
Weight System
We’ve seen a few weight systems come through the OC3D office, and the majority of them have been implemented using a plate beneath the mouse at the rear. Demanding gamers though require more precise control and that is where the Rival 600 comes in. In total there are 8 4 gram weights that can be fitted into two banks of four slots.
Both the left and right hand side plates are connected with magnets and easily slip off to reveal the eight centrally mounted weight holes, four for each side. Covering a good amount of the width of the Rival 600 you can really fine tune your experience to ensure maximum performance.
As we say, you can put as many or as few in as you desire, and in any combination. The weights simply push in and stay in place. With the side panels themselves weighing so little you can keep tinkering until you’ve found your ideal setup and then replace the side panels and get gaming.
