Steelseries Sensei Ten Review
Software
If you’re tired of those software packages that require you to page through endless tabs to get to the simplest functions then you’ll be pleased at the layout of the Steelseries Engine. It’s easy to set up your buttons, angle snapping, DPI stages and even the lighting from this single screen. In fact the only thing that we couldn’t find in our limited time with the Sensei Ten was if there is a way to set both lighting zones at the same time. Fortunately the software is clever enough to auto-sync any colour cycling you set up so even requiring a couple of clicks isn’t an issue with synchronisation. Plus with everything else requiring fewer clicks than most competitors, what’s an extra one amongst friends.
