Corsair DDR3 CL8 1600MHz XMS3 Dominator 6GB Kit
Ubisoft has developed a new engine specifically for Far Cry 2, called Dunia, meaning “world”, “earth” or “living” in Parsi. The engine takes advantage of multi-core processors as well as multiple processors and supports DirectX 9 as well as DirectX 10. Running the Far Cry 2 benchmark tool the test was run 5 times with the highest and lowest scores being omitted and the average calculated from the remaining 3.
Â
Results conclusions
As you can see, the additional bandwidth has had a noticeable effect on the 3D and gaming benchmarks. However consideration should be given to the fact that the CPU frequency was also increased along with the memory frequency which perhaps has a bigger bearing on the results.
Let’s head over to the conclusion…
