G.Skill Trident Extreme Performance F3-16000CL9 DDR3 Kit
SiSoftware Sandra (the System ANalyser, Diagnostic and Reporting Assistant) is an information & diagnostic utility capable of benchmarking the performance of individual components inside a PC. Each of the benchmarks below were run a total of five times with the highest and lowest scores being discarded and an average being calculated from the remaining three.
Focusing mainly on software and hardware information reporting, Everest also comes with a benchmark utility suitable for testing the read, write and latency performance of the memory subsystem. Each of these benchmarks were performed a total of 5 times with the highest and lowest scores being discarded and an average calculated from the remaining 3.
SuperPI is the benchmark of choice for many overclockers. It’s lightweight to download and can give a quick indication on how good a system is at number crunching. Once again, testing was performed a total of 5 times, with an average being calculated from the middle three results.
Results Observations
The G.Skill Trident kit performed exactly as expected falling just short of the OCZ Blade but thanks to the increased bandwidth, beat the Corsair kit in all of the synthetic memory benchmarks. Interestingly, Everest and Sandra were at odds when running the latency tests with Everest showing the Corsair kit faster than the GSkill (CAS 8 vs CAS 9) whereas Sandra had them equal.
Let’s move on to the 3D benchmarks…
