Mushkin HP2-5300 DDR2 1GB Kit
Appearance
The HP2-5300 is equipped with the same aluminium heatspreaders as found on the XP2 series. However, unlike the XP2 that is coloured Black, the HP2 series of memory is coloured in a visually attractive Blue.
Under some light it is hard to see the purple part of the Mushkin logo against the blue heatspreaders, but then let’s face it – once they are inside you’re PC it will be hard to notice.
