TX3 Core 360 Gaming Chair Review
Meet the TX3 Core 360
TX3 has evolved its Core series to deliver more customisability and comfort
TX3, formerly ThunderX3, has made a new addition to its CORE series of ergonomic gaming chairs. With the new Core 360, TX3 has added several new levels of adjustability to its gaming chair lineup, giving users more options for greater comfort.
For this review, we have the Core 360 “Loft Light Grey” version, which fits in nicely inside the OC3D office. This version uses multi-layer breathable mesh fabric that’s soft to the touch and has a great aesthetic. For added detail, many of the edges of the Core 360 Loft Light Grey use a soft PU leather-like material, adding nice contrast to the chair and providing a softer, smoother feel in areas that will be handled more often.
TX3 Core 360 options
At launch, six versions of the Core 360 will be available. The Loft Air version will be available in Dark and Light Grey. The “Modern” and “Racer” versions use a Leatherette material, and the “Mesh” version uses a “Breathable mesh”. Note that the Modern and Mesh versions only have one colour option. Furthermore, the “Racer” version is available in Black and Blue.
Note that while the Core 360 “Mesh” version uses a mesh material over its moulded foam, we wouldn’t consider this a “Mesh” chair. Yes, it uses a mesh material to cover its moulded foam, but that isn’t the kind of mesh that I think of when considering office chairs. This model doesn’t use mesh as a supportive material; it uses mesh as a covering. Even a quick look at the chair confirms this, but it feels misleading to call it a “mesh” office chair. Yes, we are being a bit pedantic here, but if I asked for a mesh office chair, I wouldn’t expect a chair like the Core 360 Mesh.
Synchronous Tilt
Unlike most desk chairs, TX3 chairs do not set their backrest and seat at a fixed angle. When you lean back, the backrest and seat move together at an optimal ratio, giving users better support and making leaning back more comfortable. Great news for anyone who wants a little rest.
While I like this feature, I will note that the TX3 tilts backwards faster than expected. I almost thought that I was going to fall over when I first leaned back. I suppose my usual office chair is stiffer. This is something that you may need to get used to. That said, any user would quickly get used to it.
TX3 Core 360 Upgrades
With the Core 360, TX3 is giving users more adjustability at a reasonable price. The Core 360 will cost £299.99 in the UK (via Overclockers UK), and compared with the TX3 Core Smart, it delivers more adjustment options, including TX3’s new sliding lumbar support, 360 armrests, and a new headrest design.
Size and dimensions
The TX3 Core 360 is designed for various body types. With its wide/flat base and support for users weighing up to 125 kg, it suits users with wider frames. It can also be adjusted to suit users between 160 cm and 195 cm (5 feet 3 inches to 6 feet 5 inches). For specific dimensions, consult the chart below.
A sturdy chair
In terms of build quality, the TX Core 360 is impressive. The chair is easy to construct and is highly robust. The chair comes with good instructions, and the chair came together quickly.
Note that the base of this chair isn’t a single part; it is several parts fitted together. Regardless, it is sturdy once assembled, and it assembles quickly. A solid steel base.
One thing to note about this chair’s castors is that they all use castors to deliver smooth, quiet motion on each wheel. Don’t expect this chair to squeak when it moves; expect it to smoothly glide across your office.
At the rear of the TX3 Core 360 is a handy pouch. This provides users with some handy storage, though this pouch isn’t thick enough to store much. Great for a few magazines, some documentation, or maybe a thin laptop.
Please turn to the next page of this review to see this chair’s customisation options.
