be quiet! DARK POWER 13 1000W Titanium PSU Review
DARK POWER 13 1000W
be quiet’s DARK POWER 13 packaging is simple, elegant and to the point. It says everything that it needs to say on the front without anything else. It shows the unit, its power rating, its 80+ efficiency rating, and showcasing its PCIe 5.0 power support. Perhaps it should have also listed its ATX 3.0 certification, but aside from that it says everything it needs to say.
Like most be quiet power supplies, the DARK POWER 13 is an simple design hat does not draw much attention to itself. For those with a PC case that lacks a PSU shroud, it has reflective be quiet! DARK POWER 13 lettering on its side, allowing users to showcase the fact that their PSU is a be quiet!
On the other side of the PSU is a standard PSU ratings sticker, detailing everything that users need to know about the unit. If you case has a PSU shroud, you will want to orient your PSU so that this sticker is not on show. The other side of the PSU looks much more appealing, and if we are completely honest, almost nobody reads these stickers anyway.
On the business end of the DARK POWER 13, be quiet have their connectors well labelled and well defined. None of their cables can fit into the wrong socket, and be quiet has provided enough options to make their 1000W unit ready for almost all systems.
Here we can see Be Quiet’s new Silent Wings fan, which is the reason why this new PSU from be quiet is… well… quieter than its predecessors. At 25.8 dBA under full load, this PSU is pretty much guaranteed to be quieter than anything else within your system.
One handy addition to be Quiet’s PSUs is their inclusion of a few velcro ties, which should help with cable management when you place this PSU within your PC.
Below is the 12VHPWR cable that comes with be quiet’s new DARK POWER 13 1000W power supplies. This allows this PSU to power Nvidia’s newest and most power-hungry graphics cards, like their RTX 4080 and RTX 4090.
For those who want to use be quiet’s DARK POWER 13 in Single-rail mode, the “Overclocking Key” below can be used to change the PSU’s power configuration. Most users can safely avoid this switch, but hardcore overclockers may enjoy the perks that a single, huge, PSU rail can provide.
