Coolermaster iGreen Power 430w
Coolermaster have never been a name that I’d associate with a high quality power supply, but it looks like things are about to change for the better with the iGreen series.
Combining rock solid rails along with good looks, high efficiency, reasonable noise levels and a retail price of £56 over at Specialtech, the iGreen 430w power supply should definitely be the first power supply you consider for that budget build.
Pro’s
+ Good efficiency @ 84%
+ Rock solid rails (less than 2% fluctuation)
+ Sexy electroplate finish
+ High quality sleeving on all cables
+ MTBF of 400,000 hours
Con’s
– No EPS12v connector
Editors Choice
Thanks to Coolermaster for providing this unit for review.
Discuss this review in our forums.
